Activity Forums Adobe Premiere Pro MPG Video Imported into Adobe Premiere Pro CS6 is Blurrier Than Original MPG File
  • MPG Video Imported into Adobe Premiere Pro CS6 is Blurrier Than Original MPG File
    Posted by Steve Voltmer on May 22, 2012 at 2:10 pm
    MPG Video Imported into Adobe Premiere Pro CS6 is Blurrier Than Original MPG File. What do I need to to to keep the high quality of the original MPG video?
    Tom Daigon replied 14 years, 3 months ago 5 Members · 11 Replies
  • 11 Replies
  • Ryan Patch
    May 22, 2012 at 2:49 pm
    Are you sure that you’re viewing it at full resolution? Premiere works with the original source media, so there should be zero difference in the media look.
  • Steve Voltmer
    May 22, 2012 at 4:29 pm
    Yes, I am viewing at 100%
  • Ryan Patch
    May 22, 2012 at 4:48 pm
    Right, but are you viewing at full resolution? That’s different than 100%. The 100% is on the left side of the window, but “full” or “1/2” is on the right. Make sure it’s at “Full”.
  • Ann Bens
    May 22, 2012 at 5:54 pm
    If you mean 100% for the Monitor set it to FIT.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Jeff Pulera
    May 22, 2012 at 8:57 pm
    Does the Sequence Setting match the footage? If for instance you put a 320×240 clip into a 720×480 sequence, it will be blown up and won’t look as good then
    Jeff Pulera
    Safe Harbor Computers
  • Steve Voltmer
    May 23, 2012 at 2:12 pm
    Yes, it is set to full on both the left and the right preview windows. And the sequence has the same settings as the imported .mpg clip. After I import the .mpg files into the project media list and double-click to preview them, they are far less sharp than before the import.
  • Steve Voltmer
    May 23, 2012 at 3:15 pm
    Yes, sequence settings match the footage exactly.
  • Ryan Patch
    May 23, 2012 at 5:37 pm
    Have you tried outputting and seeing if the outputted file is similarly hazy?
  • Steve Voltmer
    May 23, 2012 at 6:29 pm
    Yes. Still looks noticeably lower quality.
  • Ryan Patch
    May 23, 2012 at 9:00 pm
    Bummer man, I am out of ideas.
