Activity › Forums › Apple Final Cut Pro Legacy › MPG-2 files
MPG-2 files
Posted by Carson Hamlin on August 7, 2008 at 6:34 pmHi there,
I’m a manager in a government video production dept. We have a new Tricaster Brodcast unit that we’re doing some live things with. One of the changes Newtek has made with the TriCaster Broadcast is that it now makes straight MPG-2 files. But when we import them in to final cut pro, they don’t look very good. One of our editors said that he thought it was a problem between round and square pixels.
Any ideas anyone has regarding editing MPG-2 files would be helpful.
CarsonYuri Reznichenko replied 18 years, 1 month ago 3 Members · 5 Replies -
Kevin Monahan
August 7, 2008 at 6:58 pmMPEG 2 is not an editing format, it’s a delivery format. What other formats will this system give you? I’d be looking at anything compatible with FCP.
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Carson Hamlin
August 7, 2008 at 7:03 pmInteresting Kevin. Maybe we’re confused with formats. I do know that I can bring this MPEG-2 file directly in to Sony Vegas and edit it.
Why not FCP?
Carson -
Kevin Monahan
August 7, 2008 at 7:07 pmBecause Vegas is recently coded software and can do backflips FCP cannot. FCP is ol’ skool and ready for a make-over, me thinks.
Kevin Monahan
Yuri Reznichenko
August 13, 2008 at 9:38 amHi there.
The problem is, as far as I learned, is in how quicktime treats sizes in mpeg-2.
For example, if you make a mpeg-2 from a 720×576 (rectangular) PAL movie, you’ll see 720×540 square in both quicktime’s and final cut’s properties of the mpeg-2 file (the size is quite odd because pal is usually made square by stretching the longer side to 768).
if you make an 16×9 SD PAL movie (720×576, 1.3 aspect), you’ll get 720×404 (again, square).
when you import mpeg-2 files into fcp sequence, final cut pro looks at the dimensions quicktime provides – and automatically scales and distorts the movie back to normal size again, resulting in severe visible quality loss (worst of all is when your footage is interlaced).
What I usually did is I opened mpeg-2 in mpeg streamclip (which treats everything the way it should – right size, rect pixels) and exported movies to a low-compression quicktime format which works natively in fcp (mpeg-2 footage is very rare so that workflow was o.k. for me).
Now I did a little research with a movie consisting of alternating black and white lines 1px wide, both horisontal and vertical. After conversion to mpeg-2 and looking at the distorted array of horisontal lines I went to A/V controls (+K) and manually rewrote the dimensions to what they should be. The image returned to normal.
Quicktime won’t allow you to save the changes back to the mpeg-2 file, but you can save as .mov (either reference or self-contained with the original mpeg-2 stream inside – no recompression). this is easily imported back to final cut and no distortion or scaling happens (you’ll still have to render everything, fcp doesn’t work natively in mpeg-2).
while this would be ok for one or several files on occasion, this is not a good workaround if you have several hundreds of them. in this case you might think about a different output format on your other system.
and, again, mpeg-2 is a delivery format, it’s not meant for editing.
