Activity Forums Apple Final Cut Pro Legacy mpeg4 NTSC to Pal
  • mpeg4 NTSC to Pal
    Posted by Marc Cosgrave on May 1, 2010 at 2:09 am
    Hi
    Trying to import some mpeg4 footage shot on a Sanyo exactiTH1 into fcp.
    I’ve used streamclip to convert it and it comes up 29.97 fps so obviously NTSC.
    What’s the best way to convert this to PAL
    The other half of my footage was shot xdcam 720p and after a bit of stuffing around got that in fine.
    Thanks for the help in advance
    Marc
    Marc Cosgrave replied 16 years, 4 months ago 4 Members · 5 Replies
  • Robb Harriss
    May 1, 2010 at 2:46 pm
    do it on the outboard end in compressor. Or on the inboard end.
    Are you trying to edit MP4 in FCP? What format did you convert it to?
    Non-linear: all the time and nothing but.
  • Chris Tompkins
    May 1, 2010 at 2:58 pm
    Are you ripping a standard NTSC DVD?
    Mpeg Streamclip will convert to DV PAL.
    However you can convert to a Pal HD by selecting 50 fields or frames
    Chris Tompkins
    Video Atlanta
  • Marc Cosgrave
    May 1, 2010 at 10:42 pm
    To easy
    Compressor has done it’s job
    Appreciate that
    Coz
  • Dylan Mercer
    May 18, 2010 at 7:41 am
    Hi Marc, just interested, as I have a similar problem; What conversion settings did you use in compressor to get it to PAL?
    thanks
    Dylan Mercer
  • Marc Cosgrave
    May 29, 2010 at 5:15 am
    Hi Dylan
    I Spoke up to early. I used compressor at work and responded after I played the quicktime there but got home and it imported into fcp unrendered so I used chris tompkins settings from the same thread using streamclip and all is good now.
    Sorry about taking so long to respond but that job was put aside for a while.
    Cheers
    Marc
    Coz
