Activity › Forums › Adobe Premiere Pro › MPEG4 Export Codes in PP CS6
  • MPEG4 Export Codes in PP CS6
    Posted by John Melvin on June 22, 2013 at 1:03 am
    I’m doing a project and being asked to provide footage using the following encoding:
    Video Encoding Format: MPEG 4 AVC/H.264, 5‐8 mbps, mp4 wrapper
    Audio Encoding Format: AAC, 48 Khz, Stereo
    Video Dimensions: 720 x 480 (4:3 only, please have 16:9 letterboxed) Video Format: NTSC (No PAL)
    Audio is no issue, however, the video. If I choose MPEG 4, I cannot change it to 5-8 mbps or or 720×480 because the only options I get with MPEG4 is 3GPP 352×288 H263 or 3PPG 176×144 H263 which is nowhere close to 5 mbps.
    Strange thing is, i recently had to wipe my computer. I’m using cloud so I had no trouble installing PP. The thing is, before I wiped the old, I had many, many more options to choose from. Not sure if it has changed since last install or what.
    Any ideas?
    John Melvin replied 13 years, 3 months ago 1 Member · 1 Reply
  • John Melvin
    June 22, 2013 at 1:26 pm
    I realize now the difference is it is now PP CC and not CS6 as it was when i first downloaded….still, am I missing something on this encoding?
