Activity › Forums › Apple Final Cut Pro Legacy › MPEG4 AVC/H.264 Question
  • MPEG4 AVC/H.264 Question
    Posted by Max Frank on October 27, 2009 at 9:17 pm
    Until now, I’ve been a Beta SP/DV guy – now I’m about to start editing all sorts of weird and wonderful codecs.
    A cameraman is going to be shoot MPEG4 AVC/H.264 on a Canon camcorder overseas, and we’re trying to figure out how to get the material to me.
    Can someone please tell me, how many Gigs, more or less, is one hour of HD material captured on the MPEG4 AVC/H.264 codec?
    wayne
    Max Frank replied 16 years, 11 months ago 4 Members · 5 Replies
  • Shane Ross
    October 27, 2009 at 9:23 pm
    1080i? 720P? 24fps? 30fps? 60fps?
    Not that I know the answer, but those will help.
    BUT… you don’t edit that format. That is not an editing format. You need to convert that to PRORES, and those numbers you can get by downloading the AJA DATA RATE CALCULATOR from https://www.aja.com.
    Shane
  • Max Frank
    October 27, 2009 at 9:26 pm
    Thanks Shane,
    I’ll opt to shoot 720 30fps [that should make the file sizes smaller, right]?
    I understand I’d need to transcode to Prores to edit the files, that’s not a problem – it was more about trying to figure out how large the shoot files will be so we can make copies [burned to DVD] to have Fedexed to me from overseas.
    Wayne
  • Michael Gissing
    October 27, 2009 at 9:33 pm
    Any figures will be approximate as H264 is variable bit rate so the content will help determine the file size. As Shane said, depending on the frame rate and pixel dimensions it will fall into a range of data rate per second.
    All you need to do is multiply that average data rate by 60 to find out how much data per minute and then by 60 again to find out how much data per hour. If you have any info on the camera you can work it out.
  • Rafael Amador
    October 28, 2009 at 12:45 am
    Normally these cameras have a Data-rate selector.
    The file size will depends of the quality you choose, whatever the frame size/time-base.
    I saw that normally records between 18 and 24Mbps.
    So you will get files smaller than with DV (25Mbps).
    rafael
    http://www.nagavideo.com
  • Max Frank
    October 28, 2009 at 9:07 am
    Thanks for the feedback, gents.
    Wayne
