Activity Forums Apple Final Cut Pro Legacy mpeg2@main level export from final cut pro
  • mpeg2@main level export from final cut pro
    Posted by Ryan Early on January 1, 2011 at 4:06 am
    I have to deliver a program to a television network and they have given me these specs. Compressor doesn’t allow me to export mpeg2 with 422 chroma. Not sure the best way to go.
    Stream Mpeg Programmme Stream
    Video Compression Mpeg 2 4:2:2 Profile @ Main Level
    Video Bitrate 10-15 Mbps (15Mbps VBR preferred)
    Video Resolution 720x576i
    Video Frame rate 25fps
    Video Aspect Ratio 16:9
    GOP structure Long Maximum GOP length 15
    Number of channels 2 stereo (CH 1 / CH 2)
    Audio Sample rate 48Khz
    Audio Bit Depth 16 bits
    Rafael Amador replied 15 years, 8 months ago 5 Members · 9 Replies
  • 9 Replies
  • Rafael Amador
    January 1, 2011 at 11:03 am
    [ryan early] “Video Compression Mpeg 2 4:2:2 Profile @ Main Level”
    FC handle this only when exporting IMX or XDCAM HD 422.
    However those are “locked-formats” so you can not tweak data-rate, GOPs structure, etc.
    I think you need a more pro tool like Episode or so.
    rafael
    http://www.nagavideo.com
  • Alan Okey
    January 1, 2011 at 7:22 pm
    [ryan early] “Compressor doesn’t allow me to export mpeg2 with 422 chroma.”
    Up until recently I thought the same thing, but Jeremy Garchow posted this:
    https://forums.creativecow.net/readpost/8/1112801
  • Rafael Amador
    January 1, 2011 at 10:27 pm
    Great info alan.
    I have to refresh my knowledge.
    rafael
  • Ryan Early
    January 2, 2011 at 3:13 am
    I saw that post too, it must only be in the latest version of compressor – I have compressor 3.0.5 which doesn’t have that option for 422 export of mpeg2.
  • Jeremy Garchow
    January 2, 2011 at 5:16 am
    Yes, it came in Compressor 3.5 and FCS3.
  • Ryan Early
    January 2, 2011 at 8:41 am
    Thanks for the replies, looks like I am off to a post facility then ! Don’t want to buy the new fcs at the moment with the new fcs not far away.
  • Jeremy Garchow
    January 2, 2011 at 5:27 pm
    Episode will do it as well.
  • Craig Russillroy
    January 2, 2011 at 7:50 pm
    Hi Guys,
    Only Episode and Adobe Media Encoder are the best on the MAC PLATFORM for 4:2:2 Chroma …
    10-15 VBR in Long GOP seems quiet small for TV Delivery, as is is PAL and England normally accepts only 50 iFrame 4:2:2 I know no UK Broadcaster would accept 10-15 Mbps at 4:2:2 …
    Hope this helps try Adobe Media Encoder
    Adstream
    London, England
    Mac Pro – 8gig ram – FCS 3 – CS4 – Cinema 4D, Flip Factory, Rhozet, Episode
  • Rafael Amador
    January 3, 2011 at 1:14 am
    [Craig RussillRoy] “10-15 VBR in Long GOP seems quiet small for TV Delivery, as is is PAL and England normally accepts only 50 iFrame 4:2:2 I know no UK Broadcaster would accept 10-15 Mbps at 4:2:2 …”
    I think 15Mbps for SD delivery is really good data-rate.
    That should yield similar quality than XDCAM HD 422 50Mbps.
    Rafael
