Activity Forums VEGAS Pro MPEG2 rendering – colour levels ?
  • MPEG2 rendering – colour levels ?
    Posted by Steve Roberts on October 24, 2011 at 1:33 am
    Hi all,
    The current project I am working on will use the Main Concept MPEG2 encoders that come with Vegas Pro 10 for the first time. In the past I’ve used TMPG Enc.
    Do I need to do a levels (computer to studio) conversion to change my black and white levels or does the Main Concept codec do this compression for me ?
    THanks,
    Steve R.
    Amongst Projects
    ——— Sound, Visual and Electronic Content
    projects.amongstmyselves.com
    Steve Roberts replied 14 years, 11 months ago 2 Members · 4 Replies
  • John Rofrano
    October 24, 2011 at 10:55 am
    [Steve Roberts] “Do I need to do a levels (computer to studio) conversion to change my black and white levels or does the Main Concept codec do this compression for me ?”
    MainConcept will clip at 16-235 so you won’t get illegal levels but the proper way to do this is to adjust your levels to not be illegal in the first place. I would use Levels with the Computer RGB to Studio RGB preset because it will “scale” them to be within the legal limits instead of clipping (which is may leave undesirable effects).
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Roberts
    October 24, 2011 at 9:08 pm
    Thanks John,
    I did do a couple of tests to see if the MPEG had any info above 235 and below 16, which it didn’t. But I also noticed that the colour was the same as the AVI I put through the codec. Which has now shown me with the help of your answer that I was just chopping off the bottom and top end.
    ANOTHER QUESTION: The same material will be going to Bluray but in MP4 format. Do I need to do the same levels compression ?
    Cheers,
    Steve R.
    Amongst Projects
  • John Rofrano
    October 25, 2011 at 2:19 am
    [Steve Roberts] “ANOTHER QUESTION: The same material will be going to Bluray but in MP4 format. Do I need to do the same levels compression ?”
    Blu-ray is no different. If you are going to watch it on a TV, you should keep your colors between 16-235. You would only use 0-100 for the Internet or PC display.
    ~jr
  • Steve Roberts
    October 25, 2011 at 2:47 am
    Thanks John !
    Steve R.
    Amongst Projects
