MPEG2 Render Issue
Posted by Dan Sherman on January 2, 2012 at 8:45 pmNear end of 30 minute project, flicking in and out of black. Any thoughts?
Dan Sherman
Dan Sherman replied 14 years, 8 months ago 3 Members · 5 Replies -
Nigel O’neill
January 3, 2012 at 2:50 amCan you be a bit more descriptive please? A little bit more information might help us to diagnose your issue.
My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Dan Sherman
January 3, 2012 at 3:08 amRendering chapter based project in Vegas Pro 11 (511). Several minutes before the end of the thirty minute project the hicups start, cutting in and out of black.
MXF through Raylight Ultra on the timeline. Render is to MPEG2 for authoring and burningin DVD Architect, using Widescreen DVD Architect Widescreen video stream.System
Windows Version:7 64-bit
RAM:16 GB DDR3 RAM
Processor:Intel R Core (TM) i7 2600K @ 3.40 GHz
Video Card:nVidia 560 GTX 2Gb Video Card
Sound Card:M-Audio Delta 44
Video Capture:Vegas
CD Burner:LG Blu Ray Writer
DVD Burner:LG Blu Ray Writer
Camera:HPX 170 Panasonic
Add. Comments:Other Stuff, Asus P8H67 Motherboard 60Gb Soliod State Drive – For Windows Antec Sonata Case w.
Dan Sherman
Dan Sherman
January 3, 2012 at 6:36 pmThe breakup starts at the beginning of the render in Vegas now and continues.
I shall try to render in DVDA and see how that goes. The project was originally created in Vegas 10, but I can’t move it from Vegas 11 to ten, right?
If that doesn’t work any other options you can think of?
Thanks.Windows Version:7 64-bit
RAM:16 GB DDR3 RAM
Video Capture:Vegas
Mike Kujbida
January 3, 2012 at 7:19 pmTry rendering it out as a DV-AVI file and then use that to do your MPEG-2/AC-3 encode.
If that still doesn’t work, open up a copy of Pro 10 with this project open, do a copy/paste from 11 to 10 (track-based FX will NOT get copied), save it under a new name and try rendering again.
Are you using the latest beta drivers for your video card?
Dan Sherman
January 10, 2012 at 5:48 pmDid the cut and paste thing as suggested.
From Vegas 11 to 10.
Had to rebuild all the track FX as you warned.
Also last week downloaded Beta driver for video card.
That may have been the issue as test renders to both .avi and mpeg2 went OK.
Still not fully confident in 11 though.
In recent project an event appeared where is wasn’t supposed to be sans audio.
Also there were small gaps between events that I had to manually close.
I will stay with Vegas Pro 10 for now.
Once bitten,….
Using Vegas since Sonic Foundry days, anbody jumping to something else. FCPX, Avid, Premier Pro?
Is it just me or are others growing increasingly insecure with this NLE?Windows Version:7 64-bit
RAM:16 GB DDR3 RAM
Video Capture:Vegas
