Activity Forums VEGAS Pro MPEG2 question
  • MPEG2 question
    Posted by John Power on October 27, 2010 at 11:44 am
    A local iptv station wants me to send them an edit I have just finished on mpeg2 format………do I use the mainconcept template and what about audio is the .ac3 suitable.
    They will be using Premiere Pro to add a top and tail to my edit before converting file to flash ??
    John Rofrano replied 15 years, 11 months ago 3 Members · 3 Replies
  • Scott Francis
    October 27, 2010 at 12:20 pm
    I use the NTSC template and if it is widescreen change the aspect ratio to 16:9. This will encode audio with the video and not separate streams. You can adjust any audio variations in the tab menus under “Custom” if they require something else. This has work for me for broadcasters across the U.S……good luck!
    Scott Francis
    Mind’s Eye Audio/Video Productions
  • John Power
    October 27, 2010 at 12:39 pm
    I am working in a Pal environment ……..I am sure there is an equivalent pal template but which one ??
    Video for the Web is kool.
  • John Rofrano
    October 27, 2010 at 12:58 pm
    [John Power] “I am sure there is an equivalent pal template but which one ??”
    Try: DVD PAL
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
