Activity › Forums › Apple Final Cut Pro Legacy › mpeg2 program stream 720×576 anamorphic results in 720×404 ???
  • mpeg2 program stream 720×576 anamorphic results in 720×404 ???
    Posted by Mark Palmos on March 24, 2009 at 4:45 pm
    Hi guys
    Im in a bit of a pickle, have a deadline to produce a vid for a competition entry, and they want 720×576 mpeg2 program stream. My vid is 16×9
    I have imported my 720p clip into a 720×576 anamorphic timeline and render it in compressor.
    Compressor says 720×576, but when it renders it comes out 404 pixels high??
    Any (quick) tips on how to get an anamorphic mpeg2 at the correct pixel size?
    Thanks guys,
    Mark.
    Dennis Couzin replied 17 years, 5 months ago 6 Members · 11 Replies
  • 11 Replies
  • Jeremy Garchow
    March 24, 2009 at 4:58 pm
    [Mark Palmos] “Compressor says 720×576, but when it renders it comes out 404 pixels high?? “
    Where, in Quicktime? If so, it’s quite possible that Quicktime is reading the anamorphic flag and dislaying your movie 720×404, but in reality your file really is 720×576 anamorphic. It happens with 16×9 DVDs as well.
    Jeremy
  • Mark Palmos
    March 24, 2009 at 5:00 pm
    Hi Jeremy,
    thanks for the quick answer.
    Yes, I see the 720×404 in both QT player and VLC player, as well as when I command-I to see the info about the file.
    I have tried the 720p file in compressor directly and also tried putting that file into FCP into an anamorphic SD timeline… same result.
    sigh.
    tick tick…
  • Jeremy Garchow
    March 24, 2009 at 5:03 pm
    Are you sure you have the output set to 720×576?
  • Mark Palmos
    March 24, 2009 at 5:06 pm
    yep, 100% sure, strangely with mpeg2 there is no choice of geometry pixel aspect, it is greyed out, but here is the copy and pasted detail… tx again mate.
    Description: MPEG-2 Program Stream with MPEG audio at 48 kHz. Settings based off the source resolution and frame-rate.
    File Extension: mpeg
    Estimated file size: 103.81 MB
    Type: MPEG-2 program stream
    Video Encoder
    Format: M2V
    Width and Height: Automatic
    Selected: 720 x 576
    Pixel aspect ratio: PAL CCIR 601 (16:9)
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Selected: 25
    Frame Controls: Automatically selected: Off
    Start timecode from source
    Aspect ratio: Automatic
    Selected 16:9
    Field dominance: Automatic:
    Selected Progressive
    Average data rate: 7.2 (Mbps)
    1 Pass VBR enabled
    Maximum data rate: 8.5 (Mbps)
    Best motion estimation
    Closed GOP Size: 12, Structure: IBBP
    Audio Encoder
    Format: MPEG
    Sample Rate: 48.000kHz
    Channels: 2
    Bits Per Sample: 16
  • Michael Sacci
    March 24, 2009 at 5:10 pm
    Bring the file back into FCP and check the pixel dimensions in the bin.
  • Jeremy Garchow
    March 24, 2009 at 5:18 pm
    If it’s set, then you are good. It’s Quicktime that is at fault. I assume you are sending this for a TV transport of some sort? if so, there’s no real way to check it unless you have a hardware player. Your settings look correct.
    Jeremy
  • Mark Palmos
    March 24, 2009 at 5:21 pm
    Ok thanks guys,
    I will send the file to myself and check on my trusty PC when I get home.
    It is for playback off some Hardware player, so I reck it will be fine, even if it is 404 pixels high.
    I will report back as to what the PC says the dimensions really are… and I will try it in FCP, or even mpeg streamclip to see the size too.
    Till later
    Rendering away… again…
    Mark.
  • Ed Dooley
    March 24, 2009 at 5:49 pm
    I get the same thing all the time. It’s QTs problem.I’m compressing a 1280×720 16:9 video right now to MPEG-2, and when I open it in QT it says it’s 720×404, which it is not. Don’t worry.
    Ed
  • Rafael Amador
    March 25, 2009 at 4:26 pm
    Hi Mark,
    Don’t worry. Your MPEg~2 is perfectly 16×9.
    Open the clip in MPGStreamclip and you will see that the size is 720×576.
    I’ve sow that long ago but I think that’s just the QT Visual Setting.
    Cheers,
    Rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Mark Palmos
    March 27, 2009 at 12:22 pm
    Thanks Raffa, you are quite right, it is!
    Thank god for MPEGStreamclip…
