Activity › Forums › Compression Techniques › Mpeg2 problem overseas
  • Mpeg2 problem overseas
    Posted by Holden Crawford on March 8, 2011 at 1:16 pm
    I have a problem with sending mpeg2 to a tv station in india. i am capturing on a mac doing a hardware conversion in pal. then i encode using compressor, to a program stream. so when the material reaches them by ftp, they get some problems playing back the file. some problems include video jerkiness. i check the file on my end by encoded back for viewing purpose, and it looks fine. could it be that they are using a pc based system, and mine is mac?
    Andrew Rendell replied 15 years, 6 months ago 3 Members · 4 Replies
  • Jeff Greenberg
    March 8, 2011 at 6:23 pm
    Shouldn’t be an issue. What are the exact specs they gave you?
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Holden Crawford
    March 8, 2011 at 6:28 pm
    thanks for the reply here are the specs
    Video Format:- MPEG-2 [ 4:2:0 ], Interlaced scan
    Pixels:- 720×576
    Frame Rate:- 25fps
    Video Standard:- PAL, 8bits
    Aspect Ratio:- 4:3
    Bit Rate:- 12Mbps, Long GOP
    Bit Rate Mode:- Constant Bit Rate
    Audio:- MPEG – Layer 2, 48KHz, 192Kbps
  • Jeff Greenberg
    March 8, 2011 at 6:44 pm
    No, all of that is pretty standard. I’ve used MPEG files out of compressor on PC DVD authoring. Hmm. They should specify the actual GOP length…but that’s about all that’s worth mentioning (and with CBR, it shouldn’t really matter much about the GOP.)
    Best,
    Jeff G
  • Andrew Rendell
    March 11, 2011 at 10:50 am
    I had a similar problem last year and it turned out to be an issue with making the Mpegs in Compressor – I had left the Frame Control setting in Auto, which AFAIK should have been ok, but there was an issue with flickering. I redid the conversion with everything else exactly the same but I set the field order manually and hey presto everything worked perfectly.
