Mpeg2 looks better than Quick time but I need a great looking quicktime
I am having some strange problems that have stumped me, if anyone can help that would be a life saver.
Macpro 2×2.66ghz, 4GB DDR2 FB-DIMM
OSX 10.4.11
FCP 5.1.4
Compressor 2.3
FIREWIRE 800 HDD’s: 1TB Lacie Raid 0, 500GB Lacie, 250GB Lacie.This is basically everything that is connected to my computer.
MY PROBLEM:
I am working on an 80 min edit in FCP.FCP will unexpectedly quit when I try to FILE:EXPORT:COMPRESSOR – assuming being able to do this will solve my problem.
I am able to export FILE:EXPORT:QUICKTIME just fine and then take that into compressor and export mpeg2 for 90 min dvd best quality(default settings). The mpeg2 ends up looking better then the quicktime.
The Mpeg2 looks sharper, colors are a little more vibrant, any jagged edges are smoothed out or sharper. I’m happy with how it looks.
I make these observations by opening both in quicktime player and viewing it on my apple lcd. The quicktime is fuzzy and blurry compared to the mpeg2.
I need to master to tape for film fest viewing(dvcam,digibeta, beta sp). In case it makes a difference I’ll mention that I need to transfer to dvcam soonest.
I would think that a quicktime would be the best format to transfer seeing as that is a lot less compressed. BUT it doesn’t look as good. Should I use the MPEG2(lower quality?)?
So first Problem is that quicktime doesn’t look as good as mpeg2.
Second problem is that I have to restart the computer sometimes to refresh the ram so I can completely render large quantities of render files. Strange? But I no longer have to render anything, but I don’t know if this ram thing is connected with not being able to export FILE:EXPORT:COMPRESSOR thru FCP.
Thank you for checking this out. I hope I haven’t confused anyone or left to much info out.
Paul
