Activity Forums Apple Final Cut Pro Legacy MPEG2 into FCP
  • Posted by Andrew Timms on May 28, 2007 at 12:14 am
    Hi All –
    I have some MPEG2 files that have been exported out of Premiere Pro 2 using Adobe’s compressor app. They have the file extension .mpg and have video/audio (multiplexed?) into the one file.
    I import them into FCP but only get video. Now I know FCP is used to seeing separate Video/Audio files but is there any way I can get it to play ball with these files short of getting them re-outputted for me?
    Many thanks.
    Andrew Timms replied 19 years, 3 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 28, 2007 at 1:46 am
    If you had them send you a tape, you’d have better video, but you can demux the MPEG file you have now and work with it with “MPEG Streamclip”… https://www.apple.com/downloads/macosx/video/mpegstreamclip.html
    Still would look better if it hadn’t been cremated by MPEG 2…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Andrew Timms
    May 28, 2007 at 1:59 am
    Hi Jerry –
    What a great app. Thanks for that.
    Yeah – I’d rather have the tape also but it is our old showreel logo that only exists as MPEG2 plus a bunch of historical files that are on Beta SP tapes that are frame-drop central.
    Cheers again for your help.
