Activity Forums Compression Techniques MPEG2 HP@HL vs MP@HL
  • MPEG2 HP@HL vs MP@HL
    Posted by Roman Melekh on January 7, 2007 at 5:19 am
    Hi all!
    I have MPEG2 rip from HD-DVD disk (i dont know how this file was created)
    I know only one – file from hd-dvd, encoded as MPEG2 1920x1080x29.97, DC9, HP@HL.
    By reading Sonic Scenarist specifications i know, that HD-DVD accept only MP@HL MPEG2 files.
    Questions:
    1. How i can convert HP@HL to MP@HL without recompression ?
    2. How this converted file be playable on hardware players?
    3. By HD-DVD spec. (not Sonic) – HP@HL can be on HD-DVD?
    Roman Melekh replied 19 years, 8 months ago 2 Members · 4 Replies
  • Charles Simonson
    January 8, 2007 at 8:49 pm
    1.) You can’t change profiles without re-encoding.
    2.) Don’t know.
    3.) I wasn’t aware HP is a valid profile for HD-DVD. Wouldn’t surprise me if that has been added though.
  • Roman Melekh
    January 9, 2007 at 5:21 am
    [Charles Simonson] “You can’t change profiles without re-encoding.”
    I’m encode (with Procoder) two files: first with hp@hl and second with mp@hl.
    And i see, that this files differs….ONLY profile/level setting:
    HP@HP hex dump
    00 00 01 B3 78 04 38 33 │ 18 6A 37 51 10 11 11 12
    12 12 13 13 13 13 14 14 │ 14 14 14 15 15 15 15 15
    15 16 16 16 16 16 16 16 │ 17 17 17 17 17 17 17 17
    18 18 18 18 18 18 18 19 │ 1A 19 1A 1A 19 1B 1B 1B
    11
    MP@HL hex dump
    00 00 01 B3 78 04 38 33 │ 18 6A 32 A9 10 11 11 12
    1A 1B 1C 1C 1C 1C 1E 1E │ 1E 1F 1F 21 00 00 01 B5
    14
    it’s differs only at offsets #0A, #0B and #50. All other data is same data.
    What can you say? 🙂
    IMHO, i can to create small utility to chagne profile/level settings
  • Charles Simonson
    January 9, 2007 at 5:31 pm
    Go for it then. If it is just a matter or changing the header, which it could be if the encoding parameters didn’t negate something from one profile to the other, then a simple editing of the binary should be sufficient. You wouldn’t even need to write anything, just download a binary editor and you would be good.
  • Roman Melekh
    January 9, 2007 at 7:20 pm
    IMHO best way – once create utility
    …today MPEG2, tomorrow MPEG2.. 🙂
