Activity › Forums › Adobe After Effects › MPEG2 formats missing in AE CS6
  • Todd Kopriva
    March 31, 2013 at 3:49 am
    That sounds like a problem with the activation of these codecs, which are unlocked by a separate part of the activation/licensing system.
    Try deactivating and then reactivating the application. If that doesn’t work, deactivate, uninstall, re-install, and reactivate.
    Be sure to re-apply the latest update (Help > Updates) after you re-install.
    After Effects team blog
  • Engin Osmanovski
    March 31, 2013 at 11:18 am
    What if i render the composition in AE with lossless compression and then transfer the output to Media Encoder and re-render it to Mpeg2? Does this method have any drawbacks other than having to render twice?
  • Todd Kopriva
    March 31, 2013 at 3:17 pm
    No, there’s no problem with that. In fact, we recommend using Adobe Media Encoder over After Effects for MPEG formats (MPEG-2 and H.264).
    You can send a composition directly to AME without needing to render a master file in between, by the way. Just use the command in AME to add an After Effects composition to the encoding queue, or drag the composition from the After Effects Project panel into the AME queue.
  • Tom Daigon
    March 31, 2013 at 7:37 pm
    I look forward to the ability in the future to be able to rely on AE to be able to export all formats with no issues.Specifically, exporting to MXF OP1a AVC-100 29.97 sucks thru AME since I loose the Project Link capability which is a big speed up in my work flow.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
