Activity Forums Apple Final Cut Pro Legacy mpeg2 export not available
  • mpeg2 export not available
    Posted by Brett Clark on September 11, 2006 at 8:13 pm
    Greetings,
    I was just about to run a comparison test on some mpeg2 files and when I went to export using “quicktime conversion” from Final Cut 5.1, I found no mpeg2 option. The mpeg2 component is in the proper quicktime folder on the computer library, but it is not showing up. I tried opening the file in quicktime player and exporting from there as well, but same deal. Anyone have ideas?
    Thanks for your time and help.
    Brett
    Brett Clark replied 20 years ago 2 Members · 4 Replies
  • E. Eric johnson iii
    September 11, 2006 at 8:21 pm
    hi brett-
    i think apple is pushing people to use compressor instead of the QT conversion. i noticed that the latest versions of QT don’t have the option as well. i’ve been using compressor, and tho’ not as user friendly, it does the work fine for me.
    e. eric johnson iii
    eric@lillmonster.net
    lill monster founder/producer-director
    water channel: producer/virtual set operator
    HomeandGardenCreative.com: producer/editor
    now in principal photography – START 2 FINISH: What It Really Takes to Race A Bike
  • Brett Clark
    September 11, 2006 at 8:24 pm
    Eric,
    Thanks…and yeah, I just ran across some info saying the same. Go figure…quicktime conversion had a little more control if I remember correctly, which most times I don’t.
    Thanks again for your help.
    Best,
    Brett Clark
    September 11, 2006 at 8:30 pm
    yeah, i was bummed too… compressor has more control, but not nearly the convenience that the QT option had.
    ce la vie’.
    good luck!
    e. eric johnson iii
  • Brett Clark
    September 11, 2006 at 8:37 pm
    Thanks again…by the way, ignore my URL that is an address that is way old and I have been trying to take off my profile with no luck. Need to contact COW for this.
    Take care
    Brett
