Activity Forums Compression Techniques MPEG2 Encoding Problems
  • MPEG2 Encoding Problems
    Posted by Alex Mccunn on May 26, 2010 at 1:42 pm
    I’m trying to encode an MPEG2 D-10 file at 30mbps using Digital Rapids Stream. It encodes fine but when I open it in quicktime (or MPEGSTREAMCLIP) to check it for the clients there is no picture and the framesize is 720 x 408 and it thinks it’s a muxed MPEG1 stream. If I open the same file in VLC it plays fine. Below is a diagnostic of the file. Any suggestions?
    File: G:/D10 302.mpg
    Type: MPEG-2 Transport Stream
    File Size: 44550548 bytes
    Transport Packet Size: 188 bytes
    Duration: 11 sec
    Transport Rate: 31001599 bps
    program_number: 1
    PMT PID: 0x01E0
    PCR PID: 0x01E1
    Program Descriptors: none
    Number of PMT Entries: 2
    MPEG-2 Video Elementary Stream
    PID: 0x01E1
    stream_type: 0x02, MPEG-2 Video
    Descriptors: none
    stream_id: 0xE0, MPEG Video
    Bit Rate: 30000000 bps
    Profile: 422
    Level: Main
    Frame Rate: 25 fps
    Resolution: 720 x 576
    Aspect Ratio: 4:3
    MPEG Layer 2 Audio Elementary Stream
    PID: 0x01E2
    stream_type: 0x03, MPEG-1 Audio
    Descriptors: none
    stream_id: 0xC0, MPEG Audio
    Bit Rate: 224000 bps
    Sample Rate: 48000 sps
    Alex Mccunn replied 16 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
