Activity › Forums › DVD Authoring › Mpeg2 Encoder
  • Roman Melekh
    February 2, 2010 at 6:17 pm
    what a Source?
    pc or mac?
    you think that psychics sitting here?
  • Eric Pautsch
    February 3, 2010 at 1:22 am
    What Roman is saying is what’s your budget? There are encoders that are faster than real time. File based only. Hardware set ups, ect. Basically you’re looking at several thousand dollars for realtime or better
  • Toni Maritz
    February 3, 2010 at 6:15 am
    Hi Roman
    At this stage we are looking at both PC and MAC. My problem with MAC is that it has to go through extra compression to get it into the right format.
    We were previously using Spruce but that has died a horrible death.
    We need something of the same calibre to keep our quality up to spec.
    We are a professional company so we do have a budget available.
    All the best
    Toni
  • Toni Maritz
    February 3, 2010 at 6:29 am
    Hi Eric
    Thank you both for your input. As I’ve mentioned we’re looking for an encoder that has the same quality as Spruce. My head Engineer has looked at many encoders but there are so limitations like one is unable to hear the audio de-encode or the GOP structure is too big etc. Obviously we don’t want to have to compress the picture after the encode as this makes then takes up more time on a tight schedule.
    All the best
    Toni
  • Roman Melekh
    February 3, 2010 at 3:38 pm
    IF
    [Toni Maritz] “We are a professional company so we do have a budget available.”
    may be right to capture uncompressed video via SDI and use CCE for multipass VBR encoding?
