Activity Forums Adobe Premiere Pro mpeg2 color shift in reds & distortion on export
  • mpeg2 color shift in reds & distortion on export
    Posted by Jonathan Lazaris on March 7, 2020 at 10:20 am
    i’m in the process of editing some music videos in premiere pro. before i began, i figured i’d better export an unedited copy just to be sure i’m getting the right colors, luminance, etc. it turns out that my reds are being slightly oversaturated, but only in SOME frames. as you can see in the examples below, the girl on the right’s vest is turning out oversaturated in the re-encode, and distorted, as well – would ‘ghosting’ be a good way of explaining it?
    however, if i skip ahead to the next few frames, it’s not a problem anymore and the export is accurate to the original, but DOES end up being a problem again five or six frames later. i tried this on another music video, but didn’t have a problem. also, it’s not justy this particular video, it seems to be random. i’m writing my exports with bt601 tags as i’m guessing i should… if i instead select “unspecified”, or don’t write an sde at all, the problem still persists. the source footage is 480p ntsc interlaced 29.97. i’m using the correct field order and matching the source settings with the export accordingly. does anyone know what the problem may be?
    example 1:
    https://i.imgur.com/Tfu0skM.jpg (original)
    https://i.imgur.com/2Ilcej5.jpg (re-encode)
    example 2 (a few frames later):
    https://i.imgur.com/CcCKG4v.jpg (original)
    https://i.imgur.com/Q6px8OW.jpg (re-encode)
    View post on imgur.com
    Jonathan Lazaris replied 6 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
