Activity Forums Compression Techniques mpeg1 for a client with old machines
  • mpeg1 for a client with old machines
    Posted by Dan Denegre on September 4, 2013 at 5:11 pm
    I have a client that’s asking for compression settings I can seem to get out of Compressor. They’ve stated mpeg2,3 or 4 or any other format will not work with their ancient systems. Here’s the specs they gave me:
    MPEG-1 Muxed
    Video:
    MPEG-1
    640×360 – maintain aspect ratio
    Data Rate: 2000 kbps
    Audio:
    MPEG Layer 2 Audio
    Data Rate: 256 kbps
    Currently mpeg-1 on compressor outputs to 352×288. The data rate at 1.8 mb is fine. I tried the another method I saw which involved modifying a custom mpeg-1 setting. I edited the output dimensions in the source text file itself and tried it out – even though Inspector tells me the frame size is what I want (1920×1080), the end video produced is still locked down to 352×288.
    Thoughts?
    Ivan Myles replied 13 years ago 3 Members · 4 Replies
  • Craig Seeman
    September 4, 2013 at 6:15 pm
    It’s true that ancient (truly ancient) systems are best served with MPEG1. Compressor has very limited MPEG1 support. I’m not sure about free utilities but I know Telestream Episode and I believe Sorenson Squeeze has much better MPEG1 support.
  • Dan Denegre
    September 4, 2013 at 6:48 pm
    I think I figured it out – I used “Any Video Converter” and it seems to write higher res mpeg1 files fairly well. It’s off to the client now so we’ll see what they say!
  • Dan Denegre
    September 4, 2013 at 9:10 pm
    Darn, it looks like the client had this error:
    Windows Media Player error C00D11B1
  • Ivan Myles
    September 6, 2013 at 4:21 am
    If the client uses QuickTime, try Sorenson or Sorenson Video 3. You might need to raise the black level or gamma to compensate for color shifting.
