Activity Forums Adobe Premiere Pro mpeg troubles, con’t
  • mpeg troubles, con’t
    Posted by Kevintaylor on July 23, 2005 at 7:53 pm
    I can’t seem to find a way around mpg’ing to put my production onto a DVD. I tried an .avi, but it looks crappy. The encoder still isn’t cooperating to let me make an mpg of the project. As I said before, I’ve dowloaded the recommended updates but it has only made things worse. Is there another application I should look at to fix this? Adobe has been no help even though this problem is all over their forums. No one seems to have an answer. I just want this, in it’s original quality, on a DVD!!
    HELP!
    Kevintaylor replied 21 years, 2 months ago 2 Members · 2 Replies
  • Craig Howard
    July 23, 2005 at 9:22 pm
    Maybe this helps
    I work in PremPro and always render out (make movie) a lossless .avi (Do not Recompress)
    I then use (one of two) Ulead applcations to create any DVD I need.
    I think the apps are called:
    Ulead DVD 2 & Ulead Movie Factory 3 (something like that anyway)
    Both do the job fine and are simple to use.
    Using the encoders from PremPro offer too many options and are too complicated for me and my purposes.
    Also: I use PremPro to produce an uncompressed .avi even if making QT or other compressed format / codecs which I do with QuickTime Pro.
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Kevintaylor
    July 24, 2005 at 12:54 am
    Thanks Craig. I’m all set. I owe you a beer if you ever come to The Bahamas.
