Activity › Forums › Apple Final Cut Pro Legacy › Mpeg Toast 10 BR
  • Mpeg Toast 10 BR
    Posted by David Bryant on April 9, 2011 at 9:13 pm
    I am trying to create a Blu Ray version of a 93 minute film.
    I have encoded from FCP 6 on a Powermac through compressor using this guide:
    https://www.youtube.com/watch?v=L3IDhivbu8k
    I followed the steps (except menu creation as i want direct play) but though I set re-encode to never on toast it still re-encodes the Mpeg2.
    All I need is the create a Blu Ray auto play from an M2V and Dolby Digital file.
    Is there an easier way?
    David Bryant replied 15 years, 5 months ago 4 Members · 6 Replies
  • Chris Tompkins
    April 9, 2011 at 10:38 pm
    Choose the file “Share” option in FCP and FCP will just do it all auto for you.
    When the files are done, drag them onto toast.
    Select NEVER for the recompress.
    OR
    Export your sequence “current settings” and drag that file onto toast.
    Chris Tompkins
    Video Atlanta LLC
  • David Bryant
    April 10, 2011 at 6:20 am
    Thanks Chris,
    Unfortunately I only have FCP 6 which doesn’t have the share option but I am able to encode an M2V through compressor for Blu Ray.
    It’s when I get to Toast that, even though I set it to NEVER on encoding, it still re-encodes the clip.
    Can I make a FCP movie at current settings and drag it into toast?
  • Steve Eisen
    April 10, 2011 at 7:21 am
    Yes. Read the manual for Toast.
    Bruce Nazarian has a great book called “Fast Path to Blu Ray” It’s a very inexpensive and very informative.
    I create a h.264 for Blu Ray then drop that file into Toast.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Chris Babbitt
    April 10, 2011 at 7:32 pm
    David,
    You have to make sure that all your settings in Toast match those of your video, otherwise, Toast will want to re-encode.
  • David Bryant
    April 11, 2011 at 8:06 am
    I have tested the h.264- exported from FCP. Made a 25 minute clip and re-encoded to Mpeg2 in Toast.
    The file is a little large than DVD but not as much as I thought.
    The entire 93 minutes is around 9-10 GB. Does this sound right?
    Hard to tell on playback if there is much different in quality from the DVD. It is screenin on a cinema screen in 2 weeks so have to get a move on…
    Will try re-encoding Mpeg2 through compressor and set the same settings on Toast.
  • David Bryant
    April 12, 2011 at 1:05 pm
    Have set toast to exact setting of the M2V but it still re-encodes.
    Best results seem to be encoding a H264 through Final Cut (skipping compressor) then re-encode through Toast to Mpeg2.
