Activity Forums Apple Final Cut Pro Legacy Mpeg Streamclip & ProRes 1 & 2
  • Mpeg Streamclip & ProRes 1 & 2
    Posted by Chris Borjis on June 11, 2007 at 6:39 pm
    As some of you have noticed the ProRes codec is
    showing up on the codec list in mpegstream clip as
    ProRes and ProRes (stacked)
    I have found after testing that the topmost ProRes is HQ
    and the ProRes on bottom is non-hq.
    FYI if it helps anyone.
    Michael O’halloran replied 15 years, 1 month ago 4 Members · 3 Replies
  • Sean Oneil
    June 14, 2007 at 6:53 am
    [Borjis] “I have found after testing that the topmost ProRes is HQ
    and the ProRes on bottom is non-hq.”
    Thanks, that’s good to know. I assumed they were the same codec, just a different setting on the quality slider.
    Sean
  • Anton Seim
    June 15, 2009 at 9:57 pm
    Very helpful, thank you.
    Anton Seim
    Filmmaker
    https://www.doubleapictures.com/anton
  • Michael O’halloran
    August 16, 2011 at 9:02 pm
    Thanks Borjis,
    I’ve been using mpeg streamclip for ages and couldn’t work out why i was getting different results each time !
    I’m loath to learn whole new work flows so this is helping me stay with FCP for my DSLR and HDV-on-compact flash shoots. Many thanks.
    m
