Activity › Forums › Compression Techniques › MPEG Streamclip preview brightness
  • MPEG Streamclip preview brightness
    Posted by Arseny Preobrazhenskiy on June 3, 2014 at 2:16 pm
    Hey guys,
    i ran into a little problem on MPEG Streamclip v1.9.3b7. A few weeks ago I accidently hit some button combo, that reduced the brightness of the clip in the main window. It seems only to affect the main preview (and also the frame export, which is really annoying since i export frames everyday). I was wondering if anyone has seen this before.. i have searched the internet for all shortcuts but have found nothing that addresses my problem.
    arseny
    arsenypreo.com
    Craig Seeman replied 12 years, 3 months ago 2 Members · 3 Replies
  • Craig Seeman
    June 3, 2014 at 2:42 pm
    I’m not quite sure what key combo would cause that.
    If you believe it’s really just a settings issue than a simple solution would be to search for the MPEGStreamclip user preferences (plist) and delete it.
    One way to confirm it’s just a user setting is to create a New User Admin account and see if the issue is there as well. New Account will obviously have new user settings for both the account and the apps.
  • Arseny Preobrazhenskiy
    June 3, 2014 at 3:10 pm
    Craig, Thanks for your rapid reply. I didn’t really think of that. i deleted the file using AppClean (I think the file was hidden, and i couldn’t remember how to force them to show.) Anyways. That didn’t help.
    I attached two screenshots of the same file opened in MPEGStreamclip and QT7 to share my frustration 🙂
    If the images were a bit different, i would accept it.. but this shall not stand.
    Maybe you have any other ideas?
    Editing and Production Trainee
  • Craig Seeman
    June 3, 2014 at 3:31 pm
    [Arseny Preobrazhenskiy] “Craig, Thanks for your rapid reply. I didn’t really think of that. i deleted the file using AppClean (I think the file was hidden, and i couldn’t remember how to force them to show.) Anyways. That didn’t help. “
    You MUST confirm that it deleted the preferences. I personally don’t trust anything automated. I use EasyFind and manually delete preferences, personally.
    Did you modify the encoder setting?
    Again if it’s custom, if it’s user, you can delete the app and stored settings, preferences and the issue would be gone. It’s simply how the OS and Apps work.
