Activity › Forums › Apple Final Cut Pro Legacy › MPEG Streamclip presets
Posted by Trevor Asquerthian on January 4, 2011 at 4:29 pmAnyone know where the presets are saved so I can copy them to another Mac?
Jesse Chapman replied 10 years, 9 months ago 8 Members · 13 Replies -
Rafael Amador
January 4, 2011 at 4:52 pm -
Frank Giardina
January 4, 2011 at 5:22 pmHi…
Are you transcoding 7D footage?
Frank Giardina
17 Video Production -
Trevor Asquerthian
January 4, 2011 at 5:24 pmSorry, I realise it’s not FCP but lots of folks use MPEG streamclip to render proxies or transcode footage.
I’ve made the copy manually 😉
Trevor Asquerthian
January 4, 2011 at 5:31 pmNot in this instance… making H264 viewing quicktimes from DVCProHD sequences. Why do you ask?
Preset I’m using, FYI, is:
Compression H264, Multipass and B-Frames enabled (runs in background)
100% quality
Limit data to 400 KB/Sec (adjust to make size about 90MB and it’ll turn out under 100MB)
IMA4:1 audio Stereo / Auto
640 x 360 Deinterlace Video enabled
Upper Field First
No Rotation -
Frank Giardina
January 4, 2011 at 5:43 pmHi again…
I have a workflow for transcoding 7D raw footage. Can’t help with what you have going though, sorry.
Someone will be able to help.
Best Regards!
Frank Giardina
Rafael Amador
January 4, 2011 at 6:32 pm[Trevor Asquerthian] “Preset I’m using, FYI, is:
100% quality
Upper Field First
No Rotation”
Well you can set this very easily in MPGStreamclip.
You can export that as QT Movie, or as MP4.
You can even batch-export.
rafael -
Trevor Asquerthian
January 4, 2011 at 10:49 pmYep I can set it fairly easily – I was hoping to keep a selection of presets that I can carry around with me…
I guess it’ll be a feature request then 😉
Rafael Amador
January 4, 2011 at 11:44 pmThe truth is that the default Apple PhotoJPEG codec makes no sense.
Prores or H264 would make more.
rafael -
Martin Curtis
January 4, 2011 at 11:54 pmI had a look in the usual places (like library/application support/ ) but I couldn’t even find MPEG Streamclip prefs let alone anything else. I guess he likes to play his cards close to his chest.
It’s not scriptable either.
Adrie Noordhuis
January 13, 2011 at 8:47 amIn your user library and then preferences you will find a file with the name it.alfanet.squared5.MPEGStreamclip.plist
I just copied also to an other mac and it worked!
cu Adrie
