Activity Forums Compression Techniques Mpeg Streamclip – multiple conversions
  • Mpeg Streamclip – multiple conversions
    Posted by Alberto Mendez on November 19, 2009 at 10:22 pm
    Operating System = Mac – Snow Leopard
    Conversion Software = MPEG Streamclip 1.9.2
    Source Codec (DVD files)
    Destination Codec = Highest Resolution Video and Audio that doesn’t need to render in FCP
    Type of Destination Use = Create Demo Reel in FCP (cut down versions of original Source material), Create Flash Video Versions for Web (Full Length)
    I have all of my documentaries I have cut on DVD’s. Most of them are about an hour in length and I was hoping to rip them through Mpeg Streamclip into the highest possible file(s) so I can edit them in FCP without rendering the timeline. I have the hard drive space so I would like the files to be uncompressed (highest quality).
    I would also like to create flash video files from the original ripped files.
    Any advice and/or settings I should use in Mpeg Streamclip would be greatly appreciated.
    thank you.
    Alberto Mendez replied 16 years, 10 months ago 2 Members · 4 Replies
  • Daniel Low
    November 19, 2009 at 11:40 pm
    What were the DVD’s MPEG-2’s encoded at?
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today: 30 April 2007
    “We and Apple are neck and neck and we’re chasing the two
    other players,”
    Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
  • Alberto Mendez
    November 20, 2009 at 8:31 am
    I copied and pasted the Stream info below:
    Stream: VTS_01_1.VOB
    Path: /Volumes/A080418_00/VIDEO_TS/VTS_01_1.VOB
    Type: VOB program stream
    Duration: 0:45:00
    Data Size: 2.20 GB
    Bit Rate: 6.99 Mbps
    Video Tracks:
    224 MPEG-2, 720 × 480, 4:3, 29.97 fps, 6.57 Mbps, upper field first
    Audio Tracks:
    128 AC3 2/0, 48 kHz, 256 kbps
    Stream Files:
    VTS_01_1.VOB (1021.01 MB)
    VTS_01_2.VOB (1021.02 MB)
    VTS_01_3.VOB (208.74 MB)
  • Daniel Low
    November 20, 2009 at 10:25 am
    I’d go with the ProRes Codec.
    other players,”
  • Alberto Mendez
    November 20, 2009 at 3:02 pm
    There are several Pro Res Codecs. Which one should I use?
    444
    422 (HQ)
    422
    422 (Proxy)
    422 (LT)
    Should the Quality of Video be at 100 %
    Sound = should it be uncompressed or should I use the pass Thru setting
    Frame size = should I keep it native 720 x 480 (DV-NTSC)
    Field Dominance = should I keep it upper field?
    Should I deselect the following:
    Interlaced Scaling
    Reinterlace Chroma
    thanks for your help
