Activity Forums Apple Final Cut Pro Legacy MPEG Streamclip files make my Final Cut Pro 5.1.4 system crash
  • MPEG Streamclip files make my Final Cut Pro 5.1.4 system crash
    Posted by Mike Kommersmith on May 3, 2007 at 12:10 pm
    Hello,
    Ever since I upgraded to 5.1.4 my Final Cut Pro software will quit unexpectedly, when I select a MPEG Streamclip converted file in a sequence. If I try to park the play head, select the file, or render this happens.
    Does anyone have any ideas?
    Mike Kommersmith
    17″ MacBook Pro
    2.33 3GB Ram
    Matrox MXO
    Final Cut Studio 5.1.4
    Joe Murray replied 19 years, 4 months ago 8 Members · 11 Replies
  • 11 Replies
  • Walter Biscardi
    May 3, 2007 at 1:14 pm
    Yep, happens here too. Not sure what has happened to the software, but we keep all media converted from MPEG-streamclip in Quicktime Player only and don’t bring it into the timelines. Fortunately we only use that footage for reference and not editing.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • John Pale
    May 3, 2007 at 1:27 pm
    Hmm. I am using a bunch of Streamclip files here and not seeing this…but I am on PPC G5 and not Intel.
    What codec have you converted to? Does it do this with all codecs?
  • Walter Biscardi
    May 3, 2007 at 1:44 pm
    [John Pale] “but I am on PPC G5 and not Intel.”
    It crashes our PPC G5 Quad as well. We generally convert to DV.
  • David Heidelberger
    May 3, 2007 at 3:09 pm
    The MPEG Streamclip “Export to DV” setting converts the audio to a strange format (different bitrate or sample rate or something, I forget what, exactly). Don’t know if that’s what’s causing the problems. I created my own DV preset accessed through “Export to Quicktime” to get around that. I can’t check if that makes a difference because I’m still running 5.1.3.
    – David
  • David Roth weiss
    May 3, 2007 at 3:59 pm
    Might be time to try DVDxDV. Its not free like Streamclip, but its a fine app. if you’re grabbing stuff off of DVDs for editing in FCP.
    DRW
  • Peter Dewit
    May 3, 2007 at 4:05 pm
    The exportto dv option doesn’t work correctly with FCP. It comes out jerky and stutters and oftentimes seem to drop frames. Use export to quicktime and select the DV codec for the compressor. Those won’t need any extra rendering in a DV FCP sequence or anything. I use files like this all the time in 5.14 and it works great.
  • Andy Mees
    May 3, 2007 at 4:08 pm
    working fine for me here
  • Mike Kommersmith
    May 3, 2007 at 5:01 pm
    Thanks very much everyone,
    I will export to DV and see if this works with my system configuration. I have been demuxing the footage to M2V and AIFF with Mpeg Streamclip.
    Thanks for the input,
    Mike
  • Mike Kommersmith
    May 3, 2007 at 5:09 pm
    I just downloaded the free trial software. Thanks again for your help,
    Mike Kommersmith
  • John Pale
    May 3, 2007 at 7:33 pm
    I usually use DV50 (as in the project I am currently cutting) or 8 bit Uncompressed.
    Others elsewhere in the thread are reporting Export to DV doesnt work right, but if you use Export to Quicktime, then select the DV codec it works fine.
