Activity Forums Compression Techniques MPEG Streamclip Encoding Loop
  • MPEG Streamclip Encoding Loop
    Posted by Nathan Mcalpine on May 7, 2012 at 5:14 pm
    I’ve been searching all over and nobody seems to be having this problem. I open a file with MPEG Streamclip and export it as an H.264. I’ve done this hundreds of times in the past without any problems. The last couple months however, I export it, the progress bar comes up, it appears to be working and when the progress bar gets to 100%, it starts over from the beginning. It’s so frustrating and I feel like nobody else is having this problem.
    Anybody come across this, and if so, do you know what’s causing this problem? I’ve gotten very small files to export properly, but if the clip is over a minute or so long, it ends up in what appears to be an endless loop.
    ~ Nate
    Craig Seeman replied 7 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
  • Jeff Greenberg
    May 20, 2012 at 2:13 pm
    Have you tried trashing the prefs or trying a different user on your computer?
    Best,
    Jeff I. Greenberg
    Editor/Author/Speaker/Consulting
    My NAB seminar schedule, contact info and more
  • Nathan Mcalpine
    May 21, 2012 at 5:46 pm
    I’ve had this issue on three different computers. One time, it was a co-worker, and I was showing him the program.
    I have tried trashing my prefs and that didn’t help. It’s weird because I can export smaller files (under 50MB) fine, but when I get over a couple hundred MBs I get this loop. It’s only with H.264s too.
    ~ Nate
  • Nathan Mcalpine
    June 6, 2012 at 5:53 pm
    Dang, just had it happen on yet another computer. MacBook Pro OSX 10.7.3.
    I took a 100GB 1920×1080 ProRes Mov. Opened it in MPEG Streamclip, set in/out and trimmed it. I then set it to encode to a MP4, H.264 video. I left the office at 5PM, came in at 7AM and the progress bar was at 23% and still chugging along. Basically, it was in a loop all night. The progress bar fills and it just starts over.
    How come nobody else seems to be having this problem? Does nobody use this software anymore?
    ~ Nate
  • Rob Davis
    September 10, 2012 at 1:56 am
    hey Nathan,
    I’m having exactly the same problem with the same file formats.
    I see this was a while ago, have you had any success?
    thanks,
    Rob
  • Lili Left
    December 26, 2018 at 11:56 pm
    Hi everyone!
    I had the same problema but figured it out!
    You have to deactivate the check box that says: Multipass on Options.
    Try that, at least that worked for me 😉
  • Chris Barrett
    April 3, 2019 at 4:43 pm
    Having the same problem with streamclip – going Med 100 HD .mov to Mpeg4 720p. Took ages – perhaps 45 mins for a 1.5 min clip. I did have multipass selected but am now trying without. Perhaps I should stick with Compressor !
    Believe what I see!
  • Craig Seeman
    April 3, 2019 at 5:40 pm
    MPEG Streamclip is no longer in development. I believe it’s only 32 bit and may not take advantage of modern hardware accelerated encoding. You’d be much better off with Compressor.
