Activity › Forums › Apple Final Cut Pro Legacy › Mpeg Streamclip conversion not recognized
  • Mpeg Streamclip conversion not recognized
    Posted by Ray Ellis on August 21, 2013 at 3:48 pm
    New Member to the forum here. Thanks for everything you have posted so far
    Im using final cut pro 7.0.3 and Im shooting with a canon T3i. I am using Mpeg stramclip to convert to Prores 422 LT. When I try to move the converted file into FCP I get ” unknow File ” and the red stop sign. I also have tried prores 422 and prores 4444 . They all do the same. Can someone help?
    OS 10.6 FCP7 just downloaded mpeg stremclip
    Thanks for a GREAT forum !
    Ray Ellis replied 13 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    August 21, 2013 at 4:09 pm
    Can you play the clip in Quicktime?
    Shane
    Little Frog Post
  • Ray Ellis
    August 21, 2013 at 6:43 pm
    No…its says it doesnt recognize the file as a video file
    It may be because my original footagewas filmed at 1280×720 at 60fps I will check tonight by shooting a little clip at 1080 at 30 fps
