Activity › Forums › Apple Final Cut Pro Legacy › MPeg Streamclip Audio Issue
  • MPeg Streamclip Audio Issue
    Posted by Michael Jones on May 15, 2006 at 4:02 pm
    Round Three for MMV! I have converted the SONY Micro MV (.mmv) files to regular Mpeg2 files by using a .exe program found on the internet. I had to capture and then convert the files on a PC before I could even see the file on my Mac!
    I now have dicovered that I must again convert the files from Mpeg2 to DV using the Mpeg Streamclip conversion software. I can do this… The files are playing (Finaly) in FCP, but the audio is “Red” and wants to be rendered. I have tried to change every option in the audio setting for the sequence but can’t seem to get the audio to just play in RT!
    The only difference I see in the browser’s info is that the imported DV file is “16 bit Integer” and my sequence is “32 bit floating point”.
    Anyone have similar issues?
    Michael Jones replied 20 years, 4 months ago 1 Member · 1 Reply
  • Michael Jones
    May 15, 2006 at 4:58 pm
    I figured it out… In Mpeg Streamclip I converted the Mpegs to QT (.mov) and selected the DV/DVPro25 Codeck option. In FCP the files play without a render requirement for the audio.
