Activity › Forums › Apple Final Cut Pro Legacy › MPEG streamclip
MPEG streamclip
Posted by Steven Gladstone on February 19, 2010 at 11:02 pmThinking about installing MPEG Streamclip on the same system that has FCP. Curious about installing the quicktime alternative so that I can get MPEG support, will that cause problems with FCP or Quicktime conversion? Can I re-install Quicktime after I install the quicktime alternative? Or is it better to pay for the plug-in from apple, and not bother with the Quicktime alternative?
Thanks.
Steven Gladstone
https://www.gladstonefilms.comSteven Gladstone replied 16 years, 6 months ago 4 Members · 10 Replies -
David Roth weiss
February 19, 2010 at 11:16 pm[Steven Gladstone] “Curious about installing the quicktime alternative so that I can get MPEG support”
1) You seem to have the wrong idea about what MPEG Streamclip is and how it works. It is not an alternative to Quicktime, in fact, it uses the same codecs that QT installs. It can be used to convert files instead of QT and the other apps that use it, and it also rips files from muxed DVDs to any QT codec for additional editing as well as any other product on the market. And, it’s free to boot.
2) It in no way interferes with FCP or QT Conversion.
3) Why don’t you have MPEG support?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Steven Gladstone
February 19, 2010 at 11:36 pmI do not misunderstand MPEG Streamclip. However when downloading MPEG streamclip, there is a mention of the Quicktime alternative, which I suppose is what I should have titled the thread – sorry. The Quicktime alternative apparently Allows you to play quicktime files, and gives you MPEG2 support without having to pay for the MPEG2 codec, so I’m just wondering if there is any negative to using the Quicktime alternative to Apple’s Quicktime.
Thanks.
Steven Gladstone
https://www.gladstonefilms.com -
David Roth weiss
February 19, 2010 at 11:49 pmIf you have FCP installed you don’t have to pay for QT Pro.
I would stay away from QT Alternative.
David Roth Weiss
Shane Ross
February 20, 2010 at 12:05 am[David Roth Weiss] “I would stay away from QT Alternative. “
Because FCP relies on Quicktime. No QT, no FCP.
Shane
Read my blog, Little Frog in High Def -
Steven Gladstone
February 20, 2010 at 12:11 amOK, thanks, I thought that might be smarter.
I’ll guess I’ll pony up the $20 for the MPEG2 codec when I need it.
Steven Gladstone
David Roth weiss
February 20, 2010 at 12:16 am[Steven Gladstone] “I’ll guess I’ll pony up the $20 for the MPEG2 codec when I need it. “
Why? Why don’t you have it already?
David Roth Weiss
Steven Gladstone
February 20, 2010 at 2:23 amHaven’t needed it yet. Can play MPEG 2 on the windows machine, which now has MPEG Streamclip so easy to conert to Quicktime. Now what I need is something to convert .flv to .mov
Steven Gladstone
Matt Campbell
February 23, 2010 at 4:38 pm“Now what I need is something to convert .flv to .mov “
MPEG Streamclip will do this as well. You might need to install Perian 1.2 for this to work correctly though. Perian is a swiss army knife app that works with quicktime. it allows you to play back flv in quicktime. thus letting you use mpeg streamclip to convert.
I think what David was asking was, if you have FCP installed already, it comes with QT pro and the mpeg 2 playback component. no need for quicktime alternative junk.
OS 10.5.5, Mac Pro 2 x 3 ghz quad-core intel xenon, 9 gb ram, with BM Intensity Pro card
David Roth weiss
February 23, 2010 at 5:50 pm[Matt Campbell] “I think what David was asking was, if you have FCP installed already, it comes with QT pro and the mpeg 2 playback component. no need for quicktime alternative junk. “
That’s precisely what I was inferring Matt.
David Roth Weiss
Steven Gladstone
February 23, 2010 at 7:57 pmThanks for the Perian link.
I’m away now, but will check it all out.
I’m still used to QT Pro on windows which requires the MPEG2 plug-in. I’ll check my mac at home (with fcp) to see if it plays MPEG 2 in QT player.
Thanks.
Steven Gladstone
