Activity › Forums › Canon Cameras › mpeg stream conversion issue
  • mpeg stream conversion issue
    Posted by Azhar Zafar baloch on December 21, 2013 at 6:49 am
    Hello sir
    MPEG stream conversion problem in 5d camera mark2 or mark3 conversion
    problem h.264 convert into any kind codec
    example : proress422hq/lt, xd1080i50/p25, extra also check
    issue is contrast to much high converted footage but i check the original footage is ok
    brightness shoot is proper converted clips getting problem
    system
    2.8ghz quad-coreintel xeon
    8 gb ram
    3 tb hdd
    os upgraded installed to backward also install all types of trick try to handle
    codec install
    Azhar Zafar baloch replied 12 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
