MPEG rendering question? PNG problem?
Just installed Vegas 9.0c 64 bit on my new Win 7, HP Intel 8300CPU, 8GB RAM with a Lacie 2 Quadra 2 TB external on a firewire 400 interface, set up as a mirrored RAID.
I’m rendering a 53 minute video, DVCAM (4:3 standard def) to MPEG 2, using the “DVD Architect Video Stream” preset with CBR of 6 Mbps.
The “Elapsed time” is moving a lot faster than the “Remaining time.” From watching in Task Manager, I’ve got all 4 CPU’s bouncing around between 2% and 48%. The most CPU usage is highest when I see “live” video in the Vegas preview window. There are almost 200 graphics, saved as PNG files in the timeline, and the CPU’s show almost no activity when they hit the PNG files. The machine looks like it’s just sitting there waiting for something.
I realize that rendering to an external FW400 drive is not the fastest choice, but it worked fine on my old Pentium 4 single CPU machine, and a lot faster too.
Any thoughts? Is the problem the PNG files? Would a different still file format be better?
The machine has 8GB of memory and shows it’s got about 4 GB of memory in use. Disk access bounces up to 100% occassionally, but the majority of time it’s almost at zero.
Any thoughts? I guess render to the internal SATA drive is my next test . . . .
