Activity Forums Adobe Premiere Pro Mpeg Render Error?
  • Mpeg Render Error?
    Posted by Malcolm Desoto on March 14, 2018 at 8:10 pm
    System Specs:
    Windows 10, AMD Ryzen Threadripper 1050x, Nvidia GTX 1080, After Effects CC 2018.
    I seem to get a render error when trying to render a project within Premiere that also utilizes Dynamic Link.
    I get the attached error. The weird thing is that there are no MPEGs within my sequence. All the footage is MXF files linked to AE via Dynamic Link.
    If I render out these clips from AE as Quicktimes and import them into Premiere and replace the Linked Comps, it renders fine…
    Is this just more CC 2018 bugs?
    Malcolm Desoto replied 8 years, 6 months ago 2 Members · 4 Replies
  • Malcolm Desoto
    March 15, 2018 at 12:29 am
    So this is an error you’ve seen before? Is there anyone running CC 2018 successfully?
    I should be a full time Adobe employee with how much time I spend trouble shooting their awful software updates.
  • Malcolm Desoto
    March 16, 2018 at 2:26 am
    Damn, burn me once!
  • Tero Ahlfors
    March 16, 2018 at 4:03 am
    The MPEG preview in this case means the format you have as the sequence preview codec. You’re also rendering these previews to the system drive which might be a party of the problem. Try changing your project scratch disks to some other drive.
  • Malcolm Desoto
    March 16, 2018 at 4:55 am
    I did switch the scratch disks, which is weird. I also cleared the media cache, but maybe I need to go and manually delete those.
