Activity › Forums › Apple Final Cut Pro Legacy › MPEG IMX format
MPEG IMX format
Posted by Mike Faulkner on February 6, 2008 at 12:46 pmI have some footage in MPEG IMX format
and FCP is telling me
“codec not found, maybe using compression type without the corresponding hardware card”but I can view in Quicktime ok
any ideas
cheers
Mikebtw
i have a kona LHeBear Baker replied 18 years, 7 months ago 5 Members · 8 Replies -
Andy Mees
February 6, 2008 at 1:36 pmwhat version of FCP are you using? IMX support in FCP was introduced in version 5
Del Chapple
February 6, 2008 at 4:16 pmit should work.. make a copy of the file and change the extention to (.mov). this might work and it might eat your file..
del
you cant hear my inner voice scream… can you..?
Mike Faulkner
February 6, 2008 at 4:45 pmI have latest version 6.0.2
I used compressor to encode a ProRes 422 and this still did’nt work
mike -
Devin Crane
February 6, 2008 at 7:00 pmHow did you acquire the footage? IMX tape through E-VTR, XDCam? What software are you using to decode the MXF? Sony, Flip 4 Mac?
Mike Faulkner
February 6, 2008 at 7:54 pmI was given the footage. I used compressor to convert to ProRes.
what are my options?
thanks
mike -
Del Chapple
February 6, 2008 at 8:06 pmif you can play the file in QT then you should be able to Export from QT directly..
i’d hope
d
Devin Crane
February 6, 2008 at 9:48 pmI would agree, Export it from QT to another format DV50, ProRes, IMX 50,UC, ect. and see if that works.
Bear Baker
February 7, 2008 at 3:34 pmIf it’s possible to have the people that gave you the footage to re-dig, I’d ask for that. We have Mpeg IMX decks here. I do all my stuff at 10 bit uncompressed (Graphics and other footage are in 10 bit). The back of our Mpeg IMX deck has SDI outs and ins, so though the footage is stored on tape with this format, it can behave like a D-Beta deck.
Good luck,
BearHope all is well,
Bear Baker
