Activity › Forums › Apple Final Cut Pro Legacy › MPEG audio lost when imported in Final Cut
  • MPEG audio lost when imported in Final Cut
    Posted by Molle1018 on July 4, 2007 at 5:50 pm
    When I import MPEG files into Final Cut Pro 4.5 the audio disappears. When viewing the clip with quicktime both the audio and video are present. Once imported only the video is present. I have tried adjusting the sequence presets, but that has not helped. Any suggestions? Thanks!
    Mark Palmos replied 19 years, 1 month ago 3 Members · 2 Replies
  • David Roth weiss
    July 4, 2007 at 8:43 pm
    It has nothng to do wih your settings, the audio is muxed and FCP does not demux audio. Download MPEG Streamclip (its terific freeware) and use it to convert your MPEG to DV or some other editable video format. Then edit…
    Happy 4th of July!!!
    “No job is worth doing more than once…”
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Mark Palmos
    August 16, 2007 at 4:33 pm
    gotcha!
    is flip4mac the only wmv solution?
    ta
    mark.
