Activity › Forums › Apple Final Cut Pro Legacy › Mpeg-4 from FCP
  • Mpeg-4 from FCP
    Posted by Miriam Lefkowitz on June 22, 2010 at 5:42 pm
    I exported an hour long NTSC sequence using QT Conversion as Mpeg-4 file. The result is 3 GB. I was wondering if we exported this as an uncompressed QT movie and then used some other software to create the Mpeg-4 file, could the actual file size be smaller? The client has requested an Mpeg-4 file because their web editor insisted on.
    Miriam Lefkowitz replied 16 years, 3 months ago 4 Members · 9 Replies
  • 9 Replies
  • Michael Sacci
    June 22, 2010 at 5:56 pm
    the size is related to the bitrate used and as to the software used. Compressor and other software can get better or the same quality at lower bitrates. There are also several version of mpeg4 H264 being the most common. For that flavor there are software encoders that will allow for lower bitrates and higher quality. Episode being the favorite these days.
  • David Roth weiss
    June 22, 2010 at 6:02 pm
    Miriam,
    We need more info to help you…
    What format is your original?
    Go back to QT Conversion and repeat your process and look in the options to see what your bitrate was.
    Compressor will be a better choice for MP4 encoding, with many more controls, more variable bitrates, and better quality.
    [Miriam Lefkowitz] “I was wondering if we exported this as an uncompressed QT movie and then used some other software to create the Mpeg-4 file, could the actual file size be smaller?”
    Always export a self contained file using Export>>Quicktime Movie at current settings, that creates a QT that is precisely the same as your timeline without re-compressing. That file should then be used in Compressor.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Miriam Lefkowitz
    June 22, 2010 at 6:29 pm
    David,
    Sorry for my ignorance, but is this the info you need? – 720×480, DV/DVCPRO-NTSC, NTSC – CCIR 601, field – Lower (even), 48 KHz, 32-bit Floating Point.
    I left the bitrate at the default – restrict to 6200/kbits per sec. I also used LD AAC and medium quality.
    If I do use compressor (which I have never used) do you think the file will be much smaller? They want an under 2 GB file.
    Thanks!!!!
  • David Roth weiss
    June 22, 2010 at 7:09 pm
    You can definitely use a lower bitrate, and Compressor will almost certainly yield a better and smaller file. Compressor is very simple to use, but you will either have to have someone show you how to use it, or God forbid, actually crack open the manual (or the online version of the manual).
    BTW, there are also several presets in Compressor that might already be just right for your needs. I have to run out for an hour, but when i return I’ll check the presets myself and help you select the one that seems like a winner.
    David Roth Weiss
    Los Angeles
  • David Roth weiss
    You can definitely use a lower bitrate, and Compressor will almost certainly yield a better and smaller file. Compressor is very simple to use, but you will either have to have someone show you how to use it, or God forbid, actually open the manual (or the online version of the manual).
    David Roth Weiss
    Los Angeles
  • Miriam Lefkowitz
    June 22, 2010 at 7:20 pm
    Thank you!!! (Open the manual? What a thought. Actually, I do read the manuals.)
  • David Roth weiss
    June 22, 2010 at 9:35 pm
    Okay Miriam, it turns out there’s just one MPEG-4 preset that ships with Compressor, and oddly enough it’s pretty easy to find in the directory Formats>>MPEG-4.
    Below is the summary of the settings as they come out of the box. You will have to raise the quality setting of the video from Medium to High, but that should be about all.
    Description: MPEG-4 video with AAC audio at 48 kHz. Settings based off the source resolution and frame-rate.
    File Extension: mp4
    Estimated file size: 571.51 MB/hour of source
    Audio Encoder
    Format: MPEG4
    Sample Rate: 44.100kHz
    Channels: 2
    Bits Per Sample: 16
    AAC encoder quality: high
    Data rate: 64 Kbps
    Video Encoder
    Format: MPEG4
    Width: (100% of source)
    Height: (100% of source)
    Pixel aspect ratio: Default
    Crop: None
    Padding: None
    Frame rate: 29.97
    Frame Controls: Automatically selected: Off
    ISMA Profile: 0
    Variable bit rate, medium quality
    Hinted for streaming server with
    packet size: 1450 bytes
    and packet duration: 100 milliseconds
    Enhanced Podcast: Off
    David Roth Weiss
    Los Angeles
  • Rafael Amador
    June 23, 2010 at 2:15 am
    Hi Miriam,
    Two things:
    – For a web video you can not export 720×480 NTSC pixels. Your video will look distorted in any computer. Web videos use Squared pixels.
    – If you are unable to calculate the data rate you need to get your file 2GBs, use HandBrake. You only need to set the required file size, and the application will set the proper data rate to get it.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Miriam Lefkowitz
    June 23, 2010 at 10:32 am
    Thank you so much. This is fantastic.
