Activity › Forums › Apple Final Cut Pro Legacy › MPEG 4 encoding bitrate limit issue
  • MPEG 4 encoding bitrate limit issue
    Posted by Carlos Cantalapiedra on January 24, 2012 at 11:22 pm
    First of all,please, sorry about my english.
    I have ProRes files that I want to recompress in mpeg 4 codec (mov encapsulated) with 350Kb/s bitrate. When I do it with compressor it just works but if I try it with FCP export or media manager it doesn´t. The result files are 2150Kb/s or something and with the quicktime conversion sometimes work, sometimes not.
    I want to use Media Manager to recompress all clips and reconnect automatically but with compressor I have to do it manually.
    I don´t know why it ignores the bitrate limit.
    The compression is from ProRes 422 HQ 1920×1080 to 320×180 350Kb/s PCM Mono 8bit 32.000Khz because it´s necesary very light files(send to other continent via web for an offline edit).
    Sorry one more time about my english and thanks in advance.
    PD: I have FCP 7
    Rafael Amador replied 14 years, 8 months ago 3 Members · 2 Replies
  • Jeff Meyer
    January 25, 2012 at 2:22 am
    Try using Export -> Quicktime Conversion.
    You should be able to find the MPG options you’re looking for this way.
  • Rafael Amador
    January 25, 2012 at 9:22 am
    I don’t think MM is well fitted to do this operation.
    Try MPGStreamclip. It has a Batch Export option.
    Make sure is exporting the original TC.
    rafael
    http://www.nagavideo.com
