Activity › Forums › DVD Authoring › MPEG 2_TS file format… need help.
Posted by Ron Humer on June 20, 2007 at 1:49 pmI have to deliver MPEG2_TS 1080p 24fps format to a client and I just want to clarify how it’s created. Client can’t open.
-the way I did it….
MAC. Edited on FCP 6.0. Exported a reference. Imported reference in DVD Studio Pro. Built a TS folder for HD. Delivered folder.-is there something that I’m missing?
thanks for your help.
RonRon Humer replied 19 years, 3 months ago 4 Members · 8 Replies -
Eric Pautsch
June 20, 2007 at 2:41 pmNot sure what your trying to do. Why are you making and HD DVD? What does the client need and why?
Ron Humer
June 20, 2007 at 2:43 pmneed to deliver a mpeg2 ts to run in an instore system at best buy…. that ‘s the file format that they’re requesting… 1080p.
Eric Pautsch
June 20, 2007 at 5:50 pmmpeg 2 ts?? 1080p? Do you mean an HD DVD disc playable on a HD DVD player? Or a regular DVD? SD DVD doesn’t support 1080p but you can convert it to MPEG 2 and burn a disc. DVDSP will author a HD DVD but it won’t support 1080p MPEG streams and it needs to be burned to a red laser disc – no HD DVD burner are available.
Good Luck
Noah Kadner
June 20, 2007 at 6:37 pmWhat are the trying to play it on? An HD-DVD player, standard def player or a computer?
Noah
Ron Humer
June 20, 2007 at 6:43 pmI just found out…. a multimedia video jute-box that runs the monitors in the store. the programming needs a ts file within the TS folder instead of the .evo file that stores the video in the version that I made from DVDSP4. They’re working on pc’s…. so I’m not sure what program can do that….
any help would be great…. uncharted territory here.
Ron
Noah Kadner
June 20, 2007 at 9:13 pmNo clue- I’d suggest giving them an uncompressed 1080 QuickTime on a hard drive and letting them do the conversion. It sounds like some proprietary Windoze thing that you’ll not be able to create on a Mac.
Noah
Bill Stephan
June 21, 2007 at 6:31 pm[Editology] “is there something that I’m missing?”
Yes. The client wants an MPEG-2 transport stream (an .m2t file).
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City -
Ron Humer
June 21, 2007 at 7:10 pmYes… I figured that out based on choosing the option for audio…. Thanks so much for responding.
Ron
