Activity Forums Compression Techniques Mpeg-2’s outputting 640×480 files??
  • Mpeg-2’s outputting 640×480 files??
    Posted by Lukeinvt on August 6, 2005 at 12:12 am
    I am using Compressor 1.2.1 on a G4 Powerbook.
    I have been editing skateboarding footage shot on DV with Final Cut Pro
    Using the Mpeg-2 60 min HQ encode width 720, height 480, aspect ration 4:3, field dominance bottom first I still get a file that says 640×480.
    And actually this has not presented itself as a problem because DVD Studio Pro recognizes the files as 720×480.
    My concern is this, I have brought the compressed Mpeg-2’s into FCP sot that I may preview them on my broadcast monitor . They import as 640×480, which makes me think that DVDSP is stretching the files to 720×480, there by compromising quality.
    Whatever the case may be, I have the preset set up to output a 720×480 file, but finder says it’s 640×480 and FCP agrees.
    Any help?
    Luke
    Ben Waggoner replied 21 years ago 2 Members · 2 Replies
  • Lukeinvt
    August 6, 2005 at 12:54 am
    NTSC DV footage should have a 3:2 aspect ratio, correct?
    The only options compressor gives me are 16:9 and 4:3.
    Why is that?
  • Ben Waggoner
    August 9, 2005 at 11:20 pm
    Actually, all is well.
    While NTSC DV has a 3:2 pixel ratio (720×480), the image aspect ratio is always either 4:3 or 16:9, which is why you have those settings. Its being encoded internally as 720×480. The 640×480 QuickTime reports is the post-aspect-ratio-correction size – QuickTime Player squishes the video to 640×480 to provide the 4:3 aspect ratio.
    So, don’t fret it. It’s all working according to plan.
    My Book: https://www.benwaggoner.com/books.htm
    Squeeze and ProCoder tutorials: https://www.classondemand.net/benwaggoner/
    Compression Class at Stanford: https://www.digitalmediaacademy.org/compression.html
