Activity › Forums › Adobe Encore DVD › MPEG-2 with AC3 5.1 Audio getting pops in Encore
Posted by Alex Trudeau viriato on July 19, 2011 at 9:48 pmI am trying to create a Bluray for my documentary in Encore. I am using an Mpeg-2 and AC3 Dolby Digital 5.1 audio converted in Compressor. The audio plays fine outside of Encore but as soon as I import it into Encore it starts popping (even in the timeline).
Any suggestions?
Fps 23.98
Video Compressed in Sorensen.Alex Trudeau viriato replied 15 years, 1 month ago 2 Members · 4 Replies -
Daniel Ludwig
July 20, 2011 at 1:47 amAlex,
depending on your hardware, system and version of encore, you wont have have full-frame playback within encore.even on my 8core mac pro it will not work properly.
can you tell us how did you check your encoded AC-3? DVDSP or something else?
I never had any issue with compressor-encoded AC-3. I would suggest to mux your BD, burn it to BD-RE and check it in your standalone-player.
cheers
danny
July 20, 2011 at 4:18 amDanny,
I made 1 bluray and it had the pops in it so I went back and checked the AC3 just by using “Preview” on my mac and it worked fine, no pops. As soon as I put the AC3 in Encore I could hear the pops again. I didnt remux it yet.
I also just checked the DVD which I made in DVD Studio Pro and there are no pops. For that one I had to bring down the Kbps in the AC3 mix because I was getting the “Video Bitrate too high” error in DVDSP.
I tried using that same version in Encore for the bluray but it still had the pops.Thanks
Daniel Ludwig
July 20, 2011 at 5:43 pmhey alex,
are you sure everythings fine with your AC-3?I once had an issue – the aif-input-files haven´t been on the correct sampling-rate of 48Khz.
the result will be bad AC-3-files.
if you had the video-bitrate-to-high-error in DVDSP you have selected a wrong video-setting (much to high video-bitrate) or left some PCM audio in your project.
allways keep in mind to crete a bitbutget first.
cheers
danny
August 17, 2011 at 2:25 amI’ve remade the AC3 more times than I can count. It plays fine in DVD studio pro and in preview. The second I bring it into Encore it pops every second. Ive played with all the different frame rates and tried 16 bit as well as 24 bit. Nothing stops it from popping. I even went onto a windows PC and started fresh. Same thing.
Everything is 48Khz and 24bit.I even talked to the bluray authorizer over at Warner Brothers and he had no answers for me.
Something within Encore is acting up
