Activity › Forums › Adobe After Effects › MPEG 2 TS format
MPEG 2 TS format
Posted by John Garrou on April 5, 2010 at 2:16 pmWill After Effects render out an MPEG2 TS format video?
Please help.
Roland R. kahlenberg replied 16 years, 5 months ago 4 Members · 3 Replies -
Michael Szalapski
April 5, 2010 at 3:52 pmI’ve never tried it because of this:
Dave’s Stock Answer #3:
Don’t use AE to compress files for final delivery. The various compressors are there only to make quick ‘n dirty files showing a project’s progress to producers, clients, the kids, etc. AE is incapable of doing multipass encoding, a crucial feature that greatly improves the image quality of H.264 and MPEG-type files in particular.
Render a high-quality file from AE, and use a different application to do the compression. Popular ones are Adobe Media Encoder, Sorenson Squeeze and Apple’s Compressor, which comes bundled with Final Cut Suite. Even compressing in Quicktime Pro is better than compressing in AE.
Making good-looking compressed files is almost as much an art as it is a science. It is NOT straightforward at all. I recommend asking a few questions at the COW’s Compression Techniques forum.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Brian Charles
April 5, 2010 at 7:35 pmMichael is correct. After Effects can’t really generate a TS (Title Set). If you’re on a Mac use Compressor if you’re on a PC and have Encore make the best *UN*compressed render you can in After Effects, import it in to Encore and let it make the TS file.
April 6, 2010 at 2:59 amHi Brian, the TS refered to is an acronym for Transport Stream, a multiplexed MPEG file which is desired for digital broadcast due to its more effective error controls.
I would look at Squared 5’s MPEG Streamclip for a cheap and good solution.
HTH
RoRKSell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
