Activity Forums Compression Techniques MPEG-2 to DG Fastchannel
  • MPEG-2 to DG Fastchannel
    Posted by Samuel Smith on July 30, 2010 at 12:09 am
    Wanting to use DG Fastchannel’s dropbox for delivery of our spots instead of sending a digibeta out everytime. Here’s the spec sheet they sent me – Does anyone know which programs can achieve this (preferably something cheaper than squeeze or Episode)?
    Encoding . . . MPEG-2
    Preferred. . . . 18Mb/s
    Scanning. . . 480 60i (upper field first)
    Pixel Aspect Ratio. . . . . . . . . . . 0.9
    Aspect Ratio. . . 4*3
    Chroma. . . . . . . . . . 4:2:2 (MP@ML) (720*512)
    GOP. . . All Allowed, IBBP preferred
    Frames per second. . . . 29.97 (NTSC)
    Stream Type . . . Program Stream
    Audio – MPEG-1, Layer 2 . . . . . . . . . . 384Kb/s Stereo
    Audio – Dolby AC3 . . . . . . . . . N/A
    Digital Audio Level*. . . –20dBfs
    Luminance Level Max. . . . . . . 100 IRE
    Chroma Level Max. . . 120 IRE
    Setup level. . . 7.5 IRE
    Timecode. . . Not Used
    THANKS!!!
    Craig Seeman replied 16 years, 1 month ago 2 Members · 3 Replies
  • Craig Seeman
    July 30, 2010 at 12:20 am
    Telestream Episode and I have a preset as well specifically for DG which I’ve been using to deliver spots for years. If you’re delivering spots you should be able to afford Episode. There are very few encoders that will insert the proper Vertical Blanking interval to get a 720×480 or 720×486 to 720×512. If you’re getting a 15% agency rate for doing the media buy all it takes is about a $3000 buy to pay for Episode.
  • Samuel Smith
    July 30, 2010 at 1:07 am
    Okay, thanks for that! Would it be necessary to buy Episode Encoder Pro? Or could I get by with just Episode Encoder?
  • Craig Seeman
    July 30, 2010 at 2:13 am
    Standard is fine for DG setting.
