Activity Forums VEGAS Pro MPEG 2 Render some Help
  • MPEG 2 Render some Help
    Posted by Accountclosed on February 2, 2006 at 7:58 am
    ok i am just tired of it i just wanted to get as much good result as i am getting in .WMV format in MPEG 2 format .
    What should i have to set my quality level or else to get more Good Result in MPEG 2 Format . (now i am just tired to set randomise setting try again and again but can’t get better result in MPEG 2 Format.)
    Thanks for your time
    Regards
    ALI
    Edward Troxel replied 20 years, 7 months ago 3 Members · 2 Replies
  • Peter Wright
    February 2, 2006 at 9:22 am
    If you’re going to DVD try a DVDA preset, either NTSC or PAL according to your needs.
  • Edward Troxel
    February 2, 2006 at 2:32 pm
    Take a look at vol 1 #7 of my newsletters. I talk about many things related to MPEG2 encoding in that issue.
    NOTE: Do NOT use the “default” MPEG2 preset. That one will NOT give you good results. That’s one reason why I wrote the above article – to point out the bad settings in the default preset.
    Edward Troxel
    JETDV Scripts
