Activity Forums Compression Techniques MPEG-2 (MP@ML) encoder apps
  • Daniel Low
    January 27, 2008 at 10:11 pm
    https://www.alcorn.com/library/appnotes/encodingstandarddefvideo/index.html
    You’ll need to test if you can but Apple compressor, DVD studio pro, Episode and MPEG Streamclip could all produce possibly compliant files.
    What apps do you have and know how to use?
  • Amy King
    January 27, 2008 at 11:36 pm
    aha! thanks.
    i have Compressor 3.0.2 and DVDSP 4.2.1.
    just downloaded MPEG Streamclip and it keeps crashing each time i import a .m2v file 🙁
    i’ll try Compressor.
  • Amy King
    January 28, 2008 at 12:25 am
    Compressor worked. just created a new MPEG-2 preset using Program Stream selection and upped the bit rate.
    thanks again!
