Activity Forums Compression Techniques MPEG 2 Maximum Resolution
  • MPEG 2 Maximum Resolution
    Posted by David Mickolas on October 19, 2006 at 4:51 pm
    I am trying to export an animation from Apple’s Compressor as an MPEG2. The file’s size is 864×486. However, it seems as if I cannot export at a resolution greater than 720×480 when using the MPEG2 codec. Is this the maximum resolution allowed? The final deliverable will not be a DVD, but a file to be played on a PC connected to a plasma display. Any suggestions?
    David Mickolas replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
