Activity Forums Apple Final Cut Pro Legacy MPEG 2 MainConcept
  • MPEG 2 MainConcept
    Posted by Sam Caino on September 29, 2011 at 9:49 pm
    Is it possible, perhaps with the correct codecs installed, to import and MPEG 2 that was encoded with the MainConcept encoder directly into Final Cut Pro and edit with it? What, if any, software would need to be installed?
    Rafael Amador replied 14 years, 11 months ago 2 Members · 1 Reply
  • Rafael Amador
    September 29, 2011 at 10:13 pm
    Hi Sam,
    FC officially supports just few MPEG-2 flavors (XDCAM, HDV,..) what doesn’t means that can not cope with others.
    I think you can cut more of them. Other operations will depend.
    Try it.
    Do it in a Prores (or any other editable codec) sequence.
    You may have problems with the audio if this comes as MP2. FC can’t read it.
    If you intend to do more than a basic editing, better transcode.
    rafael
    http://www.nagavideo.com
