Activity › Forums › Compression Techniques › MPEG-2 in compressor
  • Olin Padilla
    January 19, 2011 at 1:33 am
    According to that document, the only acceptable sizes are 1080i and 480i.
    May I ask what you need with such an odd sized MPEG-2?
  • Olin Padilla
    January 19, 2011 at 1:50 am
    Disregard my last post. I didn’t read close enough.
    I was not able to immediately solve this problem using either Compressor or MPEG Streamclip.
    Good Luck.
    P.S. In my experience, small changes in resolution like that will not change the file size much, or allow for much lower of a bit rate.
