Activity Forums Apple Final Cut Pro Legacy Mpeg 2 HELP!
  • Posted by Eric Sampson on April 24, 2005 at 7:15 pm
    I have a 40 min MiniDV video and I used compressor to make it an mpeg 2 file. Can someone please tell me how I can make this one about 1 gig instead of the 1.5 gigs that is rendering out as. I already have 3 other mpeg 2 videos that I can’t reconvert so I have to work with this 40 minute video and get it down in size.? I already used A. Pack on the audio. I am using Compressor:
    One Pass VBR
    Average Bit Rate: 5.5
    Maximun Bit Rate:7.0
    Motion Estimation:Better
    I would normally try out a few settings to get it right but each conversion takes 2 hours and I only have till tonight to get this done.
    Are there any settings that I can change to possibly get it down to 1 gig in size? I dont mind going down in quality but I dont know how much to lower the bit rate and like I said Im pushing the deadline and can’t try it out!
    Thanks for any tips and setting sugesstions!
    Jim replied 21 years, 5 months ago 2 Members · 2 Replies
  • Eric Sampson
    April 24, 2005 at 7:28 pm
    Do you think setting average bit rate to 3.5 instead of 5.5 will bring me down a half a gig? From 1.5 to 1.0?
    or should I just go down to One Pass instead of the One Pass VBR?
    Thanks guys!
  • Jim
    April 25, 2005 at 12:47 pm
    I am shooting from the hip as far a space required for a 40 min to 1GB at what bit rate calculations is concerned. (GOP size is also a factor, typically 15, but could also be 12 etc.)
    I have found that a CBR of 4 with a GOP of 15 comes out to about 3.8GB for 2hrs.
    If you are going to go down to 3.5 you will want to do 2 Pass(for quality), and if you have the control of max rate you will need to bring it down close to 3.5.
    Good Luck
    Jim Cunningham
