MPEG-2, HD DVD’s, and a weird aspect ratio on Track 3?
I am basically brand new to Vegas, and am experiencing some issues with MPEG-2 rendering.
My source footage is AVCHD, 1920 x 1080, 30p. Eventually I want to burn Blu-Ray, but for starters I am rendering to DVD. I brought my project up on the timeline, salvaged my Generated Text Media (by copying from another project), set my markers, and chose ‘Render As.’ I selected Main Concept MPEG-2, and then guessed I should use the NTSC DV template (720 x 480). Then under “Custom” I saw that the project was 720 by 480, and I selected Aspect Ratio of 16:9 Display (away from 4:3). Then I set the Video Quality to High (31), and set Variable Bit Rate to the specifications Mike Kujbida suggested earlier, in another thread:
8,000,000
4,688,000
2,808,000Then just for fun I checked “Two-pass”, even though I am not really sure what that means. But it made me smile.
I am rendering, so I cannot check the Project Properties right now, but if I recall correctly, the Project Properties are 1920 x 1080, 30p, AVCHD. However, I have chosen the NTSC DVD template, because I am preparing a file to burn to DVD. I am guessing that this is part of the problem, but I have no idea why Render properties can be set differently than Project Properties to begin with. It is a little bit hard for me to wrap my mind around at this point.
Here are my symptoms:
Tracks One and Two in this project are Generated Media. Track Three is a mix (of mainly .png’s, but some other stuff as well). Track Four is my main video track (baseline presentation (and then Track Five is audio).
So far the project is at 81%, and is rendering smoothly. When the baseline presentation in Track Four is not eclipsed by the media in Track Tree everything seems fine, just like it did when I rendered to Sony AVC and the Internet 16:9 HD 30p preset. However, when the media on Track Three eclipses the media on Track Four in the Preview window, very thin ‘pillars’ of the brown backdrop material from Track Four show through on either side of the media from Track Three. It is much thinner than standard pillars: only about maybe 2-3% of the screen width on either side, but these ‘pillars’ did not exist when I was rendering to Sony AVC, Internet 16:9 HD 30p preset.
When I divide 16/9, I get a ration of 1.7777 to 1. However, when I divide 720/480, I get a ratio of 1.5 to 1, so I can understand that some kind of change has happened when I selected the NTSC DVD preset. Was I supposed to have changed my Project Properties to NTSC DVD 720 x 480 as well? And if so, how can I change Project Properties away from the properties of the footage that was originally shot?
I am sure this is probably something very simple, but I thought I should include as much information as possible, because I don’t get the whole Project Properties/Render Properties thing.
Does anyone know what I am doing wrong, and how I might be able to get the media in Track Three to fill the whole preview screen?
Thank you.
Norman Willis
http://www.nazareneisrael.org
servant@nazareneisrael.org
